macsec connectivity-association (globally)
Create and configure a connectivity-association (CA).
Configure a CA name in multiples of 4 characters (4 bytes). If the total number of characters in a CA name is not a multiple of 4, it can create interoperability issues with EXOS or Switch Engine products.
Syntax
Command Parameters
key-parity
Specifies Tx key parity using the following values:
  • even — generates even-numbered keys
  • odd — generates odd-numbered keys
If you do not specify a value for key-parity, the system defaults to 2 AN mode.
This parameter only applies to static MACsec configurations.
WORD<10-64>
Specifies the connectivity-association key (CAK) value as a 32-character (128-bit) or a 64 character (256-bit) hexadecimal string.
WORD<5-32>
Specifies a new connectivity-association name as an alphanumeric string.
Default
None
Command Mode
Global Configuration
Usage Guidelines
This command does not apply to all hardware platforms. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
